Battery corrosion clean up
boomboom
Post by boomboom »
What is the best way to clean up and prevent battery corrosion and acid build up? I have a bunch of that white stuff built up in the bottom of my battery box.
Thanks.
baking soda and water, but that can be messy in the trunk. I'd use a shop vac, then wire brush it. Undercoat or paint it after it's all cleaned up
mbouse
Post by mbouse »
To prevent its return, make sure you have CLEAN contacts and terminals to start with. It also helps to have a clean battery top.
Dielectric grease, moderately applied keeps air, and subsequently moisture off the connection.
