Metal Brake Lines
johndemar
Your car is a: 1976 Fiat 124 Spider
Metal Brake Lines
Post by johndemar »
I want to replace the metal brake lines on the 76 spider but the vendors only seem to carry replacements for the 79-85 models.
Although they do throw in the caveat of "some pieces fit 1968-78" :?
Anyone install these on a pre 79 car? And what are the "some pieces"?
If there is a source for the 76, I'd appreciate knowing about it.
John
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
ventura ace
Re: Metal Brake Lines
Post by ventura ace »
Steve Eubanks had a good set that I pulled out of a '76, and another set that was in his '76. You might be able to get those from him if he still has them.
Alvon
johndemar
Post by johndemar »
Thanks Alvon... I sent Steve an email.
I have a leak somewhere between the left rear caliper and the T fitting. But thought I should probably replace everything.
76 Fiat 124 Spider
