The flywheel had been lightened, and was WAY too thin around the hub. It broke after about 3 months of use, damaging the starter when it broke loose.
Hey! I take offense to that!fiasco wrote:Please forgive the noob-ness of this question, but . . .
Isn't the job of the flywheel to get going really fast and use its momentum to keep it going, even when it's not being pushed by the engine so that you don't have to spin it up again from scratch every time you shift gears? If so, doesn't lightening the flywheel reduce the momentum it is able to maintain? Or is this another case of "garage hacks" knowing better than the egineers?
-- se
Wow... great write-up!pastaroni34 wrote: As far as quality, a couple of weeks ago I wrote a blog post (Flywheel Lightening - Doing It Right) about what to consider when lightening a flywheel. It drives me nuts how many I've seen done incorrectly.. especially with regards to safety.
