Oil gauge instead of clock
eddy314
Post by eddy314 »
I want to replace my clock with an oil pressure gauge. Does anyone know how and where to install an oil pressure sensor on my 79 2000? Thx
mbouse
Re: Oil gauge instead of clock
Post by mbouse »
piece of cake if you are talking a stock Veglia pressure gauge!!
http://flumichigan.italiancarclub.com/T ... egauge.pdf
fiasco
Your car is a: 1969 Fiat Spider
Post by fiasco »
And if you need a sending unit, and don't want to pay $45 for new - I have an excellent one out of my '76 that just happens to be for sale. $25
I have a gauge too - just didn't have a handy picture of it - but I can send you one this evening if you want to see it. Also $25.
Buy them both for $45.
Shipping included.
-- se
Steve Eubanks
1969 Fiat 124 Spider AS | 2108 Fiat 124 Spider Classica | http://calstylestudio.com
joelbert2k
Post by joelbert2k »
Steve,If eddy314 doesn't want the oil pressure gauge and sending unit I'm interested. I didn't think about that when I got the other parts.
By the way I got them in good shape thanks!
Joel
fiasco
Post by fiasco »
PM's sent to both.
-- se
Steve Eubanks
spiderrey
Post by spiderrey »
Pimpin parts, lol
fiasco's own cyber Monday!
fiasco
Post by fiasco »
Papa needs a new pair of shoes! (and a new car)
-- se
Steve Eubanks
eddy314
Post by eddy314 »
Thanks for the info, I do need a sending unit if anyone still has one. Thx
fiasco
Post by fiasco »
Mine's gone. Sorry. Gotta be quick around here.
-- se
Steve Eubanks
spiderrey
Post by spiderrey »
I got one, same price if interested.
fiasco
Post by fiasco »
Now who's pimpin parts? :wink:
Steve Eubanks
Tempest455
Post by Tempest455 »
Hi,
My veglia gauge didn't come with the harness. I have enough spare parts to build one I was wondering if someone could translate the wire colors listed in Mr. Bouse's install guide over to the gauge terminals.
Some are easy -
White wire from speedo to the back light bulb on new gauge
Gray/Yellow from tach to oil light bulb
after that I am just guessing.
I have the following remaining connectors on the gauge:
"COM"
"31" (probably a ground for the backlight bulb)
then a spade that appears to have continuity with the oil light socket (bulb ground perhaps)
Also does anyone have a presure sender gauge? My 80 2000 only has the oil light sender.
Brandon
cbrewer13
Post by cbrewer13 »
yous should source an early gauge cluster. I have a clock AND oil in mine.
Tempest455
My clock is dead and foggy. the CD player has a digital clock.
After looking at the schematic i am pretty sure i figured out how to build a harness and what to connect to. COM gets the input from the sender. + gets 12V ignition. everything else is light bulbs that are easy to figure out
now all i need is the sender.
90 degrees in Northern VA today. put over 120 miles on her this week commuting to work 8)
