idling issue.
82spider2k
idling issue.
Post by 82spider2k »
hey, im new here and have a question that you guys might be able to help me with. i have a 82 fiat spider 2000, but am having a hard time getting it to idle correctly. it would idle at 1.5-2k rpms but now it dosnt want to idle at all. any ideas whats wrong and what can be done to fix it. thanks.
1500-2000 is much higher than that engine should idle. I'd check for vacuum or air leaks, either one will drive your FI system crazy
nickfury
Post by nickfury »
you may also try to pour some injector cleaner in the tank they may be dirty.
