Glue for Courtesy light lens
Tango
Post by Tango »
I just about had my courtesy light fixed. As someone suggested, the little ball had come out of the switch lever. I subbed a little metal rod made from a screw. Unfortunately, the lens and part of the casing was cracked and the force of putting it back in broke it. Does anyone know the type of plastic or more importantly what type of glue will work on that?
5 minute epoxy and crazy glue (CA) don't do it.
Thanks,\Tim
majicwrench
Re: Glue for Courtesy light lens
Post by majicwrench »
I went out and broke mine so I could try a couple different glues.
Of course NOT.
Duco cement is one of my favorite all purpose glues, and anything that looks like plastic gets modeling glue. And once the lense is busted, it aint ever gonna be strong enough to take off and on with out busting again. Might try glueing it on, kinda permanent, or heck find a new one.
Keith
pope
Post by pope »
NOt only that, but, the plastic and glue will heat up when the light comes on again and will soften till it fails again.
New or replace....only way to go.
Tango
Post by Tango »
It goes against my Scots-Canadian ethic, but OK. I'll get a new one. I will have to part with a $20 bill that's been in the family for years, though. Well, at least i've had one apart to see how it works now. :(
MacTim
mbouse
Post by mbouse »
Tango wrote:It goes against my Scots-Canadian ethic, but OK. I'll get a new one. I will have to part with a $20 bill that's been in the family for years, though. Well, at least i've had one apart to see how it works now. :(
MacTim
is that a Canuck or a USA $20 ?? if you've held onto it that long, it might be worth keeping around longer as an heirloom, or conversation piece. Certainly won't make you rich :mrgreen:
check out the cars being parted out in the parts for sale section. those little lamps should sell Scot's cheap.
Tango
Post by Tango »
It has a picture of the Queen on it (Victoria) so it must be CAD$.
mbouse
Post by mbouse »
at least it doesn't have a picture of a little man with a top hat and a moustache, like my bills. :mrgreen:
i like using the SHOE, so i can kick butt!!
the problem is using 5 minute epoxy, you should have only used 1 min epoxy and kept the rollover minutes :D
