Power windows
Splash
Power windows
Post by Splash »
Hi! I'm a new user. I am having difficulty with the driver's side power window regulator. The window was not working and was stuck in the up position. I removed the regulator and found 1 of the nuts that secures the motor to the regulator was missing and the cable had winded over it's self. The problem I am having is keeping the cable wound on the drum while installing the regulator assembly. Any help or suggestions would be greatly appreciated.
Thanks, John
mdrburchette
Re: Power windows
Post by mdrburchette »
Welcome to the forum, Splash. I've never seen the electric window setup so I doubt I'd be able to help you. Maybe someone will come along soon that can help. I'm wondering if it's similar to the manual setup.
Splash
Re: Power windows
Post by Splash »
It is the same set up but, the cable goes around 4 pulleys insead of 3. I have a new problem though. Wile messing around with the regulator I found that regulator gets stuck in a certain spot. So it looks like I need a new regulator. If any one has any idea where I can locate one I would be greatful.
Thanks, John
mbouse
Re: Power windows
Post by mbouse »
Hey, Splash. welcome to the site.
any pictures of your car?
note: technical advice sought is always best to put in a different topic section. you'll get much better responses there.
rlux4
Patron 2022
Patron 2022
Re: Power windows
Post by rlux4 »
Welcome to the forum Splash. How long have you had your Spider? What year is it?
Nosey, ain't I?
Ron Luxmore
rlux2n2@gmail.com
