Hello,
I have a 1978 124 with some bulb replacement questions.
- Headlight bulb. Which one do I buy and where?
- Front and rear side marker bulbs. Which one and where do I buy them?
Thanks for your help in advance.
Young
Headlight and side marker bulb
Re: Headlight and side marker bulb
You can remove the bulbs and take them to any local auto parts store and they will have what you need.
Thanks, NebraskaSpider.
I got my headlamp relaced, but couldn't take the plastic cover off of the side markers.
Any instructions apprecaited.
Young
Young
If side marker are the rectangular ones like the spider at the top of the page then the plastic lens is a solid piece. The light receptacle twists counter-clockwise and pulls out the back. Easy to try on the rears.
Joel
Joel
sO does the plastic cover and the chrome piece come off together? Or does the plastic housing detach from the chrome square piece?
- Your car is a: 1976 Spider - sold
On the front side of the light, The lens sits inside the chrome surround and has two studs that go thought the assembly. On the backside, there is a metal bracket that is clamped down by two wingnuts attached to the lens studs to hold the light in place. You do not have to remove the light assembly to replace the bulbs. Just twist the bulb holder and pull it out.
76 FIAT Spider - Sold
The chrome piece is kind of like a bucket or a pan. The studs are embedded in the plastic and go thru the metal.
Aw to heck with it here's some pictures:
Joel
Joel
That's a fancy floor you've got in your garage!
Trey
You guys are awesome!
I'll do this over the weekend and post some images for other folks to see as well.
How do I get myself a copy of the repair manual with all these great diagrams? Or is it the owners manual?
Check out International Auto. They should have a workshop manual you can buy.
- Your car is a: 1978 Pininfarina
Young,
I just got a 78 124 and I ordered the Brooklands Shop Manual from IAP
It's easy to read and well laid out; Someone on here recommended it ... echo ...echo
clipper
clipper
