83 Pinina Cooling fan stays on... drains the battery.
On my trip back from Freak Out the alternator quite working.... then worked again... then quite again.
Made it home safely and took the alternator in for repair.. also had to pull the radiator, took that in for refub also.
I put it all back together last night .. learned about purging the cooling system...
Went for a short ride needed a bottle of "Jack Daniels" every thing worked fine.
Pulled the garage and the colling fan turned on like it always did.
Got up this morning and the battery was dead.
I look at the wiring diags on line and will ohm the temp switch which I think is on the bottom of the rad.
Any other thoughs?
Elial
Cooling Fan stays ON
Re: Cooling Fan stays ON
You think the metal foil on the Jack Daniels label is shorting something out?
- ga.spyder
Was the Jack for you or the car?Are you sure it was the fan staying on,or is it possible that alt isnt charging? I know that is your new $200 battery!! I'm glad the pix I sent you helped.
Craig
Craig
Craig Nelson
Fling It Around Turns !
Yours is a different year model than mine but does yours go to a relay that could be faulty? You have the black wire properly grounded too, right?
no relay on the late cars. Unplug the switch in the bottom of the rad to test it. Since you had the rad out, and consumed a bottle of Jack, could you have swapped the switch and fan plugs? That would cause the fan to run all of the time
MarkSo Cal Mark wrote:no relay on the late cars. Unplug the switch in the bottom of the rad to test it. Since you had the rad out, and consumed a bottle of Jack, could you have swapped the switch and fan plugs? That would cause the fan to run all of the time
Thanks for the feed back.
I'll double check the wiring .. The top fan wire does have a splice in it so I put it back in the same connection to the fan.
Also the fan switch has fast tabs that push on. so I didn't disconnect it at the plug. ( Must be Americano switch)
I Ohmed the switch and it is closed all the time. I have ordered a new switch today, should be here by the end of the week.
So I'll ohm that one before I install it.
