Replacing the dash clock?
- Your car is a: 1976 124 Spider
I have 2 fiat clocks, neither of which works.
I bought a volvo clock for a couple of bucks -- it worked for a while; apparently Volvo folks have to replace their clocks semi-regularly, too.
So I'm looking for a replacement clock that will fit in place of the original -- ideally, I'd like to put one of the Fiat gauge faces on it.
Any suggestions?
Matt
Any suggestions?
Matt
Re: Replacing the dash clock?
I have three. (Suggestions, that is.)
1. Clocks can be repaired. Could be expensive though, I don't know. Radiopilot rebuilt his with good results.
2. Post for a replacement in "Parts Wanted"
3. They come up regularly on Ebay as people part out a car.
clocks i have owned for my 1978 & 1980 Spiders:
1. the originals
2.
that's right... only the original factory clocks. i did, however, change the crystals. maybe i am just lucky, but i don't think so. these clocks DO work well.
i suggest that you find an original clock, if it needs a new crystal replace it and use what matches perfectly with your other gauges. if you cannot wait for one to appear at Evil Bay, then contact one of our suppliers:
http://www.fiatparts.com
http://www.midwest124.com
both have used gauges handy, for resonable prices.
then, if that doesn't work out for you... my second suggestion is a stock oil pressure gauge. they aren't the most accurate thing, but are fun to watch, and are the same size as the stock clock.
1. the originals
2.
Oops. I didn't think of the vendors for used parts.
Make that four suggestions.
Once i get my car going strong i plan on using an IAP clock http://www.international-auto.com/class ... uments.cfm
Though i wouldn't use it unless i had the stainless rings around all of my guages
I went to the local craft store. Found a 2" quartz clock that has an internal AAA battery paid all of $8. Took the Fiat clock apart and put it's dial in the L-cheapo sprayed the gold dress ring flat black. Oh I glued in a mimi lamp so I could see it at night. It ran flawless for 4 years and then just before Freak Out I had to replace the battery. No one commented that it was not the original clock, even though it has sort of Victorian hands
Most Fiat clocks do work for a long time. Its the lens that gets old and yellow.
unlike the rest of the gauges, the clock bezel is plastic, which causes the yellowing over time.
a 2" el-cheapo flashlight bezel works just as good as a hobby shop clock... and costs less.
I agree the original clocks are very reliable. Mine not only had the discolored crystal but the gear to set it had cracked and was slipping on the shaft. I could not set the time.
Putting in the L-cheapo was sort of a whim thing but has worked pretty well.
- perthling
That's what I was looking for here Down Under. Found a shop which had to get one in, said it should arrive in September... 2007. I'm still waiting for their call to let me know it's arrived.spider2081 wrote:I went to the local craft store. Found a 2" quartz clock that has an internal AAA battery paid all of $8. Took the Fiat clock apart and put it's dial in the L-cheapo sprayed the gold dress ring flat black. Oh I glued in a mimi lamp so I could see it at night. It ran flawless for 4 years and then just before Freak Out I had to replace the battery. No one commented that it was not the original clock, even though it has sort of Victorian hands
I've parted out a number of Coupes and none of their clocks have worked. the clock in my '74 Spider will work if you give it a kick-start by adjusting the hands - once you disconnect and reconnect the battery it just stays stationary. And the clock in my one-owner '74 CC has just gone on the blink. Still, 35 years out of a clock isn't too bad IMHO.
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
Perthling
- jfrawley
- Your car is a: 1982 Spider
The original clock in my '82 keeps perfect time....not the right time, but perfect none the less. The gear to set it correctly has left the building, so I pull the fuse, wait until the time catches up with the clock, reinstall the fuse, and I'm good to go. PIA, but effective!
- Razooli
- Your car is a: 1982 Fiat Spider 2000
@spider2081 Just did this and finally have a working clock that I can set and that keeps accurate time... what a great idea! What kind of "mini lamp" did you use for light?spider2081 wrote:I went to the local craft store. Found a 2" quartz clock that has an internal AAA battery paid all of $8. Took the Fiat clock apart and put it's dial in the L-cheapo sprayed the gold dress ring flat black. Oh I glued in a mimi lamp so I could see it at night. It ran flawless for 4 years and then just before Freak Out I had to replace the battery. No one commented that it was not the original clock, even though it has sort of Victorian hands
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
1982 Spider 2000
- Your car is a: 1982 FIAT SPIDER 2000
Bag that clock and put a round picture of your family there.... These clocks are a classic conflict for the love of making it right!! A subtitue guage, either oil pressure, or temp that matched the others, ie fuel, water temp, but that requires some enginering if it is to be functional..... Just by the feedback on this clock issue; the writing is on the wall, IT ANI'T WORTH IT!
- ga.spyder
Wear a watch!!!
Craig Nelson
Fling It Around Turns !
