Does anyone have any advice on removing a stuck rotor? This front right one is the first I pulled from the car so I imagine I'll have a similar experience with the others. I did take the hub off and tried the obvious - put it on a block of wood and hammered the crap out of it. Didn't budge at all. I even tried jumping on it
I did notice that there are 2 flat areas of the hub that look like you can slip a tool into. Is there such thing as a rotor puller? Would it help?
