Bad turn signal or bad 4 ways?
JimM
Post by JimM »
I was driving to work last week and had turned left with turn signal working. 11/2 miles later turn right and no signals. Check everything out next day and find that the hazard signals don't work either. I have checked the fuses and all grounds, but find nothing wrong. I switched fuses to make sure ut still nothing. Could the problem be the hazard relay? Is there any way to check the relay to see if it is working or not. Any suggestions would be greatly appreciated.
Thanks to all in advance for your help. Jim
mbouse
Re: Bad turn signal or bad 4 ways?
Post by mbouse »
could be the hazard switch too.
relays are not expensive, swap a new one in.. or one from a functioning vehicle and test your circuit.
mdrburchette
Post by mdrburchette »
Are you saying you don't have right side turn signals or both sides stopped working?
jfrawley
Your car is a: 1982 Spider
Post by jfrawley »
I had the very same issue not too long ago. I found that when I installed the radio into position, it pulled one of the wires loose on the 4-way flasher switch and caused it to make Intermittent contact. I also redid the ground pods. The problem has not resurfaced.
John Frawley
Frederick, MD
1982 Spider
http://www.dcfiats.org
JimM
Post by JimM »
Sorry for the delay, but we had some personal issues at home with Dad. In order--New hazard switch. No turn signals and no hazard lights. I have checked all ground pods, but I will check the wires going into the hazard switch. Thanks all.
