Does the Pertronix MR-LS1 work with a stock dual point dizzy and stock coil?
thanks
Chris
Oakland, CA.
Converting to electronic ignition
- Your car is a: 81 spider
Re: Converting to electronic ignition
I don't know but I just installed the MSD 6AL IGNITION BOX on my car yesterday and it works both with points or electronic. So when you want to convert to no points, its effortless. You need to loose the secondary set of points because they become pointless with the MSD (Multi Spark Discharge) It gives directions on how to do that. Quite easy. I also used the MSD coil. Best part is that I can simply plug in the rev limiter chip and set it to 3000 so my teen boys don't blow'er up. Haa
- kilrwail
Yah, save the 7000 rpm chip for yourself
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
