Guibo failure and mystery driveway stain
4babycar
Post by 4babycar »
Well, on my way home from work on Friday the guibo lost a large chunk as I was passing another vehicle. Fortunately, it was only about 3 miles from home so I took it easy and parked her. After the monsoons let up and I could take a good look, I also found a mystery stain in the driveway. The stain was a milky white with no other discernible color or odor. Would the guibo failure cause a transmission seal to fail and could this be the cause of the mystery stain? Also, if that is the case, how difficult is it to repair? My Dad and I have done the guibo replacement before and it isn't too bad but the thought of transmission work scares me and my wallet! Thanks!
Re: Guibo failure and mystery driveway stain
the only time I've seen a tranny problem from a guibo failure was complete destruction when the driveshaft started flailing around.
Milky substance is usually oil mixed with water. Was the stain under the tranny?
4babycar
Post by 4babycar »
Well, as usual Mark, you are right. Once the spot got a little daylight to it and it dried for about 30 minutes the milkiness went away and only a motor oil residue was left. I have a small leak from a failed oil pan gasket, that I have been putting off for nicer weather and I guess coupled with the rain I drove through Friday and the additional rain all day yesterday that is likely where it came from. I couldn't tell precisely where it came from since I could only see it after I rolled the car forward in the driveway. I knew that it was close to the tranny but I couldn't tell just how close. Thanks for the reassurance. I know the drive shaft hasn't bounced around too much so hopefully all is good once I replace the guibo.
racydave
Post by racydave »
Leave the band on the Guibo untill it is installed, and ( oops :oops: ) take the band off before you drive it!
speedracer
Post by speedracer »
OK, I've read this thread over and over and I still cannot figure out what the "Guibo" is. :oops:
Can somebody help me out here? :?:
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Post by adrians »
The rubber donut shaped device that joining the two halfs of the drive shaft. ( has 6 bolts )
http://reviews.ebay.com/Flex-Donut-Disa ... 0002540632
THE FLEET
2014 Abarth "SS"
1981 Spider 2000 (Legend Industries Turbo - minus the Turbo)
1978 X1/9 1.3 Dual IDF 40's, Coupe Cam, Allison Header/Exhaust
1971 128 Sedan 1100cc, Coupe Cam/Headers
Motokhana Special 127 rear engined Rail 903cc
