Fuel Filter Location
I have a replacement filter for my 81 Spider 2000. Where is filter located? Any tips for the process?
Re: Fuel Filter Location
underneath the car, next to the fuel pump. Relieve the pressure in the system first, have a drain pan ready and clamp off the hose from the tank to the pump
There are probably different ways to do it, but I just disconnect the hose to the cold start injector. Be ready for a pretty good spray when it comes off. Put a rag over it when you're ready to pull it off so you don't get gas in your face.
