turn signals (removed bumper)
I took my front bumper off and just moved the turn signals into the holes behind were they were on the bumper for a temp. fix. Where do those little round signals come from like the ones on the car on the page (fits in the old bumper holes)? I think I will check the local parts store to see what they have but I don't remeber seeing anything like that.
Re: turn signals (removed bumper)
Hi there. There is also a thread from "custom stuff" that is about diy bumper delete.
If you want to put something together yourself. Marks looks easy to do.
- danaspider
- Your car is a: 1979 Spider 2000 79 vw bus
Mark is the man. His come with all the pieces and parts. A little cutting on the existing holes. Not much.
I did mine last year and am very happy.
Here are a couple of pics. the first showing the right side lights and the 2nd showing the rectangular covers I did. Final painted body color.
Have fun.
Have fun.
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
79 Spider 2000
carb
- TulsaSpider
Those doooo look nice! Is that a grill you fabbed up? Your first pic didn't show up but I found it though!
- danaspider
Tulsa, I got tired of just looking at the rectangular holes. What I used was sheet brass, painted body color, to make a plate, with wire mesh (1/4 inch chicken wire screen) painted flat black. I used allen head screws to mount, into expansion bolts. (those rubber plugs with threaded insert).
Been thinking that could add brake ducts, or a fresh air dump into the engine compartment. But until I decide what to do it looks a bit more finished, I think.
The whole kit from Mark took maybe 2 hours to install.
Luck Dana
79 Spider 2000
carb
79 Spider 2000
carb
