Does anyone have technical information for the following motor number?
ID: 132AB1 (4319431) that was the only numbers I could find on the motor.
Robert
Motor identification
- Tappy
Re: Motor identification
hi robert
can it be that that is the number on the head ? i've found that number in a list of cilinderheads
enginenumber would be located above the oil filter or on the block on the driversside
FineItalianAutomobile Technology
No these numbers are taken from the engine block ID: 132AB1 (4319431), the cylinder head has ID: 4314402 and then some V10S62. Its a european motor and I haven´t been able to find any information on internet.
Only information I have is that it should be 1800cc.
- Tappy
i have two lists to look at and cant find back the number , i suggest you search above the oilfilter then , my previous block had 4356114 and 132 db 2a 0 casted in the side , above the filter it says 132.DB.000 that number i can redirect to an fiat argenta
i believe that the .000 in the end specificates if its european or .040 american/californian emission related If so yours should end 000
here are my lists :
http://www.netikka.net/ville.vieri/tc/tclist.htm
and
http://clublancista.org/archivos/incl/l ... eabd806efa
here are my lists :
and
- Your car is a: 1982 Fiat Spider 2000 Turbo
This lists model/engine IDs, but I believe it covers only North America models http://www.mirafiori.com/id/table124.html
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'62 Lancia Flaminia 2.5 3C Convertible
'68 Lancia Fulvia Sport Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
'12 Abarth 500
Okay this might be the number for engine identification (132.C1000) but I’m not 100% since it was quite dark in the garage, I will bring a flashlight next time.
- Tappy
yes that would be an 1800 engine :132AC1.000..................1756 (84 x 79.2).........118 (5-spd)hp
this list :
this list :
