PCV valve
TulsaSpider
Your car is a: 1978 Spyder 124 2L
PCV valve
Post by TulsaSpider »
Has anyone ever fabbed up a PCV valve for one of these? There is sorta one I suppose you have some suction there at the oil separator tube but it's just open to the atmosphere. I wonder which is greater. The volume of the air coming out of the oil seperator tube, or the suction from the tube coming out of the carb? Has anyone tried to put the vacuum tube in the oil tube then seal it up? Come on I know you've tried it, or at least thought about it!!
Re: PCV valve
the volume of vacuum doesn't need to equal the crankcase pressure. It only has to lower the pressure enough to prevent too much pressure. The vacuum increases as the throttle opens if the carb is clean. There is a disc on the throttle shaft that increases the vacuum opening as the throttle opens. That disc operates as a pcv valve
TulsaSpider
Re: PCV valve
Ok I was trying to alleviate some oil leaks.
lvacordian
Your car is a: 1978 Fiat Spider 1800
Re: PCV valve
Post by lvacordian »
Does anyone know where I can purchase the PCV valve disc that is on the carburetor throttle shaft? Nobody seems to have one
TulsaSpider
Re: PCV valve
No PCV on these? maybe post a pic?
Flatspyder
Your car is a: 1971 Fiat Spider
Re: PCV valve
Post by Flatspyder »
You could take the oil cap and oil filler kneck from the valve cover of an 850 spider and weld in place where the fiat124 oil cap hole is. That has a pcv tube in the oil filler kneck. If you really bent on doing it. your logic is sound enough.
All I need in life is something to eat, something to do and something to love.
JConnerly
Re: PCV valve
Post by JConnerly »
To address the oil leak issue: The owner of a Alfa spider told me if your Italian car isn't smoking a little or leaking oil, you better check your oil.
lvacordian
Re: PCV valve
I'm referencing the disc that Mark referred to a few posts up. It's inside the carburetor on the throttle shaft. The factory manual refers to it as a pcv valve. Mine is toast; totally melted. Anyone have one for sale? I need one for a 78.
