oil leak?
warrenrhen
Your car is a: 1979 fiat 124 spider
oil leak?
Post by warrenrhen »
I had my 79 Fiat 124 down for a while, desmogging it, installing headers, replacing intake manifold and carb I just fired it up today since doing the work. There's a major oil leak on the right side front. Looks like oil running out the holes that held the smog pump bracket. Is this possible? If so, is there a certain length bolt I should put in there so I don't restrict oil from going somewhere where it should be going? I also didn't plug the holes in either side of the head that take the exhaust gas from the exhaust manifold to the EGR valve because I figured there should be nothing traveling through there since there's headers on one side and a single plane manifold on the other therefore it's non functional.
Cheers, Warren
79 124 spider
18 Dodge Charger R/T
20 Vespa 300 GTS HPE
Nut124
Re: oil leak?
Post by Nut124 »
Are these holes in the head or in the block?
If oil is really coming out of unused bolt holes, then you would need to use a short bolt and a copper washer or possibly thread sealer.
warrenrhen
Re: oil leak?
bottom of the block on the right front. As I said the holes from the smog pump bracket
Cheers, Warren
79 124 spider
DRUMMOND
Re: oil leak?
Post by DRUMMOND »
Do you mean these ones?
If so yes you need to seal them with short bolts and thread seal
warrenrhen
Re: oil leak?
DRUMMOND wrote:Do you mean these ones?
Yes, Thats the ones. Thanks for the info
Cheers, Warren
79 124 spider
Nut124
Re: oil leak?
Post by Nut124 »
Drummond, that engine is so clean, spotless! Did you just build it? Running?
maxm50
Re: oil leak?
Post by maxm50 »
Same thing happened on my car... I had an AC compressor bolted to a bracket attached to those holes. Ripped that right off and promptly sprayed oil out of the holes. D’oh! Right now I just have the bracket bolted back on to stop the oil leaking out, but I got some bolts and copper washers sitting in the “parts to install” bin in order to save some weight.
1981 Fiat Spider 2000
2011 BMW 335i M-Sport
1971 Honda CB450 Twin
DRUMMOND
Re: oil leak?
Post by DRUMMOND »
Reply to nut 24
Yes just rebuilt 3 years ago
this was a pre start up pre oil pressure spin up before starting. I heard this sputtering noise and looked down oil was pouring from the holes
I couldn't believe they tapped into the oil chamber?? :(
SteinOnkel
Re: oil leak?
Post by SteinOnkel »
DRUMMOND wrote:Reply to nut 24
They did the same thing on the exhaust manifold.
These are good engines all things considered, but this BS is almost unforgivable.
gchocevar
Your car is a: 1979 Pininfarina 2000
Re: oil leak?
Post by gchocevar »
I ran into this after my last rebuild. Also, I found out that the engine bracket has some blind tapped holes and some through holes into the block where hot oil drips down and seeps through these taped srews. I need to clean these out and apply sealant.
gchocevar
Re: oil leak?
Post by gchocevar »
