Hi... I'm going to apologize in advance for what is most likely a dumb question. Not a mechanic... forgive me.
The wire that connects to the coolant t outlet... what is it and what does it do?
I was detailing the engine bay and it snapped in 3 places because it was so brittle. I asked a friend and they said.. "just fix it, who cares what it does". True... but I need to know.
Newbie question... What the heck is this wire?
- Ragzz
- Your car is a: 1983 Spider Europa
Re: Newbie question... What the heck is this wire?
It is the temperature sensor for the coolant, and the car will not run without it. Good thing you noticed it! Save a lot of heartache.
Best thing is to get an FI manual and go through the various sensors and checks and make sure that they are all in working order.
Here is a list of Bosch L-Jetronics manuals and other resources available:
BOSCH L-JETRONIC MANUAL – BEST ONE:
http://foxed.ca/rx7manual/manuals/BOSCH ... Manual.pdf
http://dtec.net.au/Tech%20Articles.htm
FUEL INJECTION DEBUGGING
http://www.hiperformancestore.com/Ljetronic.htm
http://www.njfiats.org/joomla/images/st ... BoschL.pdf
FUEL INJECTOR CLEANING:
WWW.OKINJECTORS.COM
www.witchhunter.com
FUEL INJECTION MANUAL
http://www.mirafiori.com/faq/fiatFI_may2002.pdf
FUEL INJECTORS CHART
http://users.erols.com/srweiss/tableifc.htm
L-JETRONIC MANUAL
L-JETRONIC
http://mastertechmag.com/pdf/1988/11nov ... ronic2.pdf
http://jenniskens.livedsl.nl/Technical/ ... tronic.pdf
L-JETRONIC FI MANUAL (FROM VW)
https://www.type4.org/manuals/ljet/index.html
WWW.OKINJECTORS.COM
www.witchhunter.com
L-JETRONIC MANUAL
L-JETRONIC
- Ragzz
AWESOME. Thank you. I figured coolant temp sensor but didn't understand the link to FI.
I'm learning as I go. I did some reading and now I get it.
thanks again.
thanks again.
Once the various sensors are proven to work as they should, and there are no air leaks, it works pretty well! But it can take a few bucks to get there... Suggest that you go through the various FI manuals and test all the sensors, fuel pressure, etc. Not overly difficult. Try to take as many of the readings as possible back at the ECU under the glove box, to eliminate cable problems effecting the readings.
Setting the TPS is a little tricky, the bottom line is, just make sure you hear it "click" just as you open the throttle plate manually (with engine off), and that it is actually switching on and off back at the ECU.
