Aloha from Hawaii Island
HawaiiSpiderman
Post by HawaiiSpiderman »
Recently purchased a "C" condition 1979 Spider 2000. Red/black
Runs well. Needs a top and boot, a tire or 2, has very little rust, and I'm sure there are a few other small items that need restored.
$1700USD :D
Ordered a shop manual, but I will definitely have questions along the way while restoring this beauty!
Aloha
Land Toys:
1979 Fiat Spider 2000
1968 Corvette L82 Hardtop Conv.
1984 Buick Grand National unmarked
2011 Ford F150 Lariat 4x4 Crewcab
Water Toys:
1969 Islander 23' Trlr Sailboat
1987 Chris Craft 284 Amerosport
JohnMc
Your car is a: 1970 Fiat 124
Re: Aloha from Hawaii Island
Post by JohnMc »
Sounds like a great price.
HI sounds like the perfect place to have a Fiat 124.
They do have "drain or weep holes" in the floors. You might want to crawl under to see that these triangular drains are open and not closed or clogged.
Enjoy!
Post by RRoller123 »
Rust free at that price is excellent!
HawaiiSpiderman
Rroller123: I wouldn't say rust free. There are spots of bare metal rust and some paint bubbles. However, all panels are whole, undented and most rust spots are very small, the largest being about the circumference of a baseball.
After delivery, I made a quick visual go over and took pics of every inch of the exterior and bottom and both trunk and engine bays. The following are the obvious fixes needed, and I'm sure to find more on closer evaluation:
Mechanical Issues to address:
Tire leaks 2
Rear brakes
Top frame broken at front bow
Fuel delivery system, elec in trunk
Battery hold down bracket missing
Rear end leak? Clean/check
Transmission leak? Clean/check
Driveshaft rebuild
Electrical Issues to address:
Fuel system circuit-switch in trunk?
Coolant fan circuit-switch on console?
Backup lights need connected
Side marker lights need connected
Interior light missing
Parts to be replaced:
Top and frame
Ignition switch
Trunk lock missing
Rear seat back missing
Left rear taillight cracked
Interior light
Some items are in 2 categories to keep my shopping list complete.
Overall I still think this was a great deal. Drivetrain seems solid, but I will do further testing. 60k miles. I think most of the time and $ will go toward cosmetic restoration.
I'll figure out how to upload a few pics for review. Feel free to chime in with YHOs and if you have a part that I need or know where I can obtain.
Mahalo (Thanks)
Aloha
Land Toys:
Water Toys:
For parts, many members here are good sources. For new (and sometimes used as well), our commercial friends are: Auto Ricambi, Allison's Automotive, Vicks and Midwest-Bayless. "spiderparts", a member here on the forum, is also an excellent choice. Good luck, that to-do list seems quite manageable!
