Transmission rebuild
- Your car is a: 1980 spider
- Nanonevol
Re: Transmission rebuild
Third gear used to grind but you replaced second?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
Yes. 3d gear was ok. But the synchro was bad. 2d gear was bad but the synchro good. Now all gears work fine but i decided to change the oil from gl-4 (80-90) to gl-1 (as recommended) and after 60 miles of driving the oil came out with a lot of glitter (wear from synchros). Idk if the lucas oil i got was bad but i can only hope the synchros still good.
- MattVAS
- Your car is a: 1976 Fiat Spider 124
I'd say give it a little time. A freshly rebuilt transmission can be a bit tight.
Also, how high are your RPMs when you're downshifting. These transmission aren't known for liking a high rev down shift.
Matt Phillips
Vick Auto - Manager
http://www.vickauto.com
Vick Auto - Manager
