I have not removed it yet but wondered if there was a way to adjust the tachometer without destroying it?
Mine is about 400 rpm off and would like it a little more accurate if possible.
John Mc//
How to adjust the tachometer?
- Your car is a: 1970 Fiat 124
- kmead
Re: How to adjust the tachometer?
There is a potentiometer inside the housing, some have drilled a hole in the housing to be able to access it while the unit is running.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
Try cleaning the ground connections. Mine used to slowly increase rpm at constant speed as the gauge heated up. After cleaning the connections the tach always reads the same rpm at a constant speed.
1974 Honda CB350F
1981 Fiat Spider 2000
