Grinding sound and feel on left curves
Zoofly
Post by Zoofly »
I'm getting a grinding feel and sound from the front end of my 78 Spider when I steer to the left when driving. I don't hear it on left turns, only when up to speed (over 20 miles an hour) on curves in the road. Could that just be a loose brake pad? I also notice from time to time when braking the car moves left and right slightly.
2020 124 Spider Abarth
2019 Alpha Romeo Stelvio - sold
1977 Triumph Spitfire
2017 Fiat 124 Spider Classica - sold
1999 Jaguar XK8 - sold
1998 BMW Z3 - sold
1988 Pontiac Fiero - sold
GeorgeT
Your car is a: 1982 Fiat 124 Spider
Re: Grinding sound and feel on left curves
Post by GeorgeT »
You need to inspect all suspension parts both front and rear. It could be worn out bushing or loose pieces.
DieselSpider
Post by DieselSpider »
First check for loose wheel bearings. They really need to be checked at every oil change along with all the front end suspension bolts being checked for proper torque.
Eli's Suspension Guide on Mirafiori is a good read on what to check aside from the wheel bearings.
https://www.mirafiori.com/124susp/
Zoofly
Post by Zoofly »
Thanks for the link. Very helpful. It described some of the things I've experienced. I see big spending in front of me.
1998 BMW Z3 - sold
lglade
Post by lglade »
If you're willing to do the work yourself (and it's not all that difficult), the cost can be quite reasonable. Our trusty vendors all sell shocks, springs, bushings, control arms, etc.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
TheBender
Patron 2019
Patron 2019
Post by TheBender »
lglade wrote:If you're willing to do the work yourself (and it's not all that difficult), the cost can be quite reasonable. Our trusty vendors all sell shocks, springs, bushings, control arms, etc.
I just had all of my bushings, the drag link and both upper ball joints replaced. Parts were very reasonable, definetly the labor is the expense.
phaetn
Your car is a: 1974 Fiat Spider 1800
Post by phaetn »
Sounds like bearings to me -- especially the grinding on curves, not corners, and the hunting/darting.
Axle nuts could be loose (they can back off and require restaking) or the bearings themselves could be shot. Just went through this myself.
When the car is lifted with the wheels off the ground AND THE CAR SUPPORTED BY AXLE STANDS, see if there is wiggle as you try and move the front wheel holding the tire at the top and bottom. I stress that the car needs to be supported by more than a floor jack because you don't want it falling while you have your fingers under a tire.
Wiggle when holding the tire on the left and right could also be other items (ball joints, steering linkages) but when holding it top and bottom is axle nut or bearings. Bearings occasionally need repacking with grease.
phaetn
1974 CS1
32/36 DFEV; CompuTronix ign.
9.8:1 c/r; 40/80 intake cam w/ Isky springs
Vicks' SS header & adj. cam pulleys
A/R's progressive coils, Koni Yellow dampers
205/50-15s on CD-66 style rims
Momo wheel, Corbeau seats w/ 5 pt belt
pics and HD vids
Zoofly
Post by Zoofly »
Thanks, phaetn. Once I get the floor jack and stands I will do the test you suggest. I've seen video on how to replace/repack the bearings. That is something I am comfortable with doing. What/where are the axle nuts you are referring to? And what does "restaking" mean?
As you can see I'm a novice at auto repair but I love to learn and do these things myself. Much appreciate all of the help on this forum.
1998 BMW Z3 - sold
