Transmission Bellhousing Seal Replacement
- Odoyle
Trying to replace trans bellhousing seal. I already removed large belleville thrust washer, but not sure how to remove seal.
- Your car is a: 1975 Spider
Re: Transmission Bellhousing Seal Replacement
take a plastic hammer and drive the seal housing out of the bell housing. Shouldn't take but a moderate tap to do so. then use a punch to drive the seal out from the front side. There is a oil weep hole you can use. you will also want to replace the rubber o-ring when you do this. Should be in your gasket kit
son has 78 spider
son has 78 spider
