Hi all - just looking for some input on replacing the rear window frames as seen in the following link;
http://www.vickauto.com/newstore/index. ... ts_id=4144
The assemblies on both my car and a spare convertible top I picked up are in rough shape. The overall frame is solid, but the window frames / attachment points are rusted out and fused together. I'm having a hard time figuring out how the original window frame could be removed and a new frame installed to the convertible top. Is there welding involved? Or a bit of hardware that I'm not seeing because of rust?
Thanks for your help!
Rear Window Frame Replacement
- Your car is a: 1981 Pininfarina
Re: Rear Window Frame Replacement
I did a similar repair to mine. I don't have any photos. Once the repair pieces were welded in I wire brushed the frame as good as I could and then applied POR 15 to the frame. I did this in 2005 many miles ago and the top has seen a lot of rainy days. No issues so far.I rebuild mine with steel square tubing and it involved welding
That is perfect. Thank you for the photos and thank you for the feedback. That helps me mentally prepare for what I'm up against!
