79-85 Electronic Igntition on 74-78?
Odoyle
Your car is a: 1983 Pinafarina Spider
Post by Odoyle »
Could an electron ignition setup from 79-85 (distributor, ignition control module, and vacuum advance) work on 74-78 1800cc carbed spider?
blazingspider
Your car is a: 1977 fiat spider
Re: 79-85 Electronic Igntition on 74-78?
Post by blazingspider »
Absolutely!! I'm running the later electronic ignition setup on my 77. The one caveat is whether you can use the vacuum advance capsule or not and that will depend on whether you have the correct vacuum source for it. Lot's of debate about which is the correct source too, ported or manifold vacuum but you can run without the vacuum advance attached as well, which is currently what I'm doing.
johndemar
Your car is a: 1976 Fiat 124 Spider
Post by johndemar »
It will certainly work, but you might also consider something like a Petronics system.
BTW, if you want an original set up, I have one I bought years ago and still sitting in the box it was shipped in.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
Ravq124
Your car is a: 1978 fiat 124 spider
Post by Ravq124 »
Hello, I have a 78 that the PO installed an 79 distributor and now I'm having trouble with it at the coil. I saw on another post and it mentioned two other wires that are attached to the ignition coil since my car doesn't have those wires would it still affect the ignition coils performance?
riverdadd
Your car is a: 1975 Fiat Spider 1977 Alfa Spider
Post by riverdadd »
Ignition control module has 4 terminals. 2 terminals to distributor, other 2 terminals go to the + & - sides of the coil
