95 amp bottom bolt
red107
Contact:
95 amp bottom bolt
Post by red107 »
Anybody have issues with the bottom bolt on the 95 amp alternator? I installed it and the bottom bolt is tight but its not snug. Its diameter is much smaller than the original bolt. I was thinking about a shim/collar/ to tighten it up. I remember post on a fix for this, but did a search and can't find it.
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
scrapironchef
Your car is a: 79 Spider
Re: 95 amp bottom bolt
Post by scrapironchef »
I believe the instructions with the unit suggest drilling out the mounting holes and using the original bolt. I'm shelf aging mine while I finish up some other work but I plan on drilling it out when I get to it.
Larry
TX82FIAT
Post by TX82FIAT »
Used original bolt as suggested. On a side note. I've had the AR 95 amp alternator for six years now with no issues at all. I think it was one of the best mods done to the car.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
red107
Contact:
Post by red107 »
Thanks for the info. I will drill it out.
