Damage from Jack Stand Point
ChrisK
Post by ChrisK »
Hello Everybody,
I preemptively admit to my stupidity for either 1. doing something that damaged my spider, 2. worrying about nothing, or possibly both. Despite trying to do some research on where to put the jack stands when jacking up the right side rear of my spider, I couldn't seem to find a definitive answer. Being that I cannot put the jack stand on the jack point that I need to lift the car, I decided to put the stand on what I though was a secure structural rail. Now, if i am recalling correctly the rail looked a little warped before, but now I am worried that my jack placement has damaged that rail. Below are links to pictures of where the stand was and what it looks like after. Sorry I can't figure out how to make the show up in the post
If that piece is damaged, is in something that should/our could be fixed.
Thank you all so much for your advice!
seabeelt
Patron 2019
Patron 2019
Re: Damage from Jack Stand Point
Post by seabeelt »
Cant see the photos. Are we talking front or rear?
KevAndAndi
Post by KevAndAndi »
Can’t see the photos, but for future reference, the cross member is a good jacking point for the front, and the diff is a good one for the rear.
I usually drive the front wheels onto Rhino Ramps, jack up the rear from under the diff, and then place stands at either end of the axle. If I need to take a front wheel off, I jack up the cross member, put stands under the member and the closest jacking point, and pull out that ramp, leaving the other ramp in place.
I use the jacking points as little as possible because I don’t trust them. Perhaps that is irrational.
Kevin
1981 Spider 2000
DieselSpider
Post by DieselSpider »
Unless I am working on the cross member I use that as the jack point placing the jack in the middle and the stands on both sides of the jack and use the center of the diff with a wood block as a cushion on the jack plate and place the stands as near to the axle ends as possible.
Post by RRoller123 »
+1 on that.
