1983 Courtesy Light wire color and configuration.
mldmat
Your car is a: 1983 Pininfarina Spider
Post by mldmat »
Can anyone identify the wire color and where they connect to the courtesy light fixture for me?
My choices for the three required are:
Violet/black female spade no plastic conn. (I found on other posts that this is one but when connected, it pulses with the turn signal flasher)
Red/green with plastic connector
Grey/yellow with plastic connector
Single Black with plastic connector
Three black together with one female spade no plastic conn.
If I can determine the three wires that go to the light, I should be able to figure out the other three.
Thanks, any info appreciated.
mldmat
Re: 1983 Courtesy Light wire color and configuration.
Post by mldmat »
Solved:
Red/green to the single side.
Violet/black to the top (if the red and green single spade is pointed right)
Single black to the bottom
