Thought I would put this out there and see if anyone else has encountered this
Rear brakes seem to wear out about every 2500 miles.
A couple years ago I went through the entire system after a MC failure. Put new hoses on each of the calipers along with caliper rebuild kits , new rotors and pads. Only hose I didn't change was the center one that feeds the distribution block over the rear axel
Last summer I had to replace the rear brakes as the right rear was down to the rivets. So I thought must be the caliper as the left rear was worn, but certainly not like the right rear. Rebuilt the caliper again paying special attention to the piston seals and even broke the whole caliper down to clean ad grease the e-brake portion. Replaced rotors and pads both sides
So now here I am approx 2500 miles later and the right rear is down to the rivets and left rear is worn but not like the right rear just like before.
I'm wondering if that hose over the axel has something to do with it? Proportioning valve?? new MC ????? They should NOT be wearing that fast. By contrast the fronts a wearing evenly and still show good pad depth after approx 5-6 k miles as you woul expect
Got my new CD3s all dusty Grrrrrrr
Any thoughts from the considerable brain trust here???
Rear brake excessive wear
- seabeelt
- Patron 2019
- lglade
Re: Rear brake excessive wear
For cars working normally, the front brakes do about 70% of the braking due to weight transfer. So if your rears are wearing out that quickly, then I'd want to know if the fronts are truly functioning properly. If you jack up the rear end, and put the transmission in neutral, can you easily turn the rear wheels? You should be able to tell if the rear brakes are dragging.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
2015 Subaru Outback
2017 Ford Focus RS
2,500 miles would indicate either the parking brake is set too tight or the hose you did not replace needs to go. The rears must also be showing signs of heating if your going through them so fast which is also not good for the diff, axle bearings or the tires.
- nelsonj
My parking break locked up and wore through my pads and one rotor (passenger side) in no time. I later had to rebuild a rear break cylinder. I had a new parking break cable put on and that solved the issue. However, I don't really trust my parking break after that and I tend to use 2nd gear rather than the break.
I've put well over 10K miles on the breaks after that without issue.
Good luck.
Good luck.
Simi Valley, California
Spider 1800
Romans 10:9
Great point about the front brakes not working well, causing the rears to do all the work. I would bleed the heck out of the fronts and make sure the master cylinder is fully bled too. You might want to pull the MC and bench bleed it. I would also pull the rear caliper pistons and make sure the guts inside the piston are clean and working well. There's a fairly complex ratchet mechanism inside the rear pistons that makes the parking brake system work.
Kirk
Kirk
- seabeelt
- Patron 2019
Well, I replaced the center hose and found a rusted metal line starting to leak to boot. Changed both. Brakes seem to function much better. That center rear hose was definitely plugged. Collapsed from the inside. Couldn't see or blow through the hose at all. Put on new pads and rotors of course. Think I still have a small air bubble in the right rear caliper, but overall a satisfactory job, and I didn't break anything either Did find that the compensator arm bushing where it moves at the axel is missing. Guess I will have to make something for that as I haven't seen anything on any of the vendor sites
