Taillight gasket
dinghyguy
Your car is a: 1981 spider
Taillight gasket
Post by dinghyguy »
Does anyone know how to soften and stretch a taillight gasket to make it fit properly?? Warm water is not enough
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
DieselSpider
Re: Taillight gasket
Post by DieselSpider »
Old steam iron on the steam setting with the gasket under a lint free shop towel. I also soften vinyl flooring that way to may it easier to removed or to soften the glue where its bubbled and press it back down without burning the flooring.
dinghyguy
Post by dinghyguy »
I will try that, does it stay stretched?
This came about because I cleaned the lenses in the sink and also drilled out al the rivets on the taillight boards and cleaned, tinned and soldered the bulb housings to the board. Anywhere between 2 and 5 ohm reduction in resistance along the board paths. All are less than 1 ohm now. One more electrical task done.
Then I went to put the lenses back on and no way would the gaskets stay in position
Next is the ignition switch rebuild and brown wire install
Dinghyguy
