Does this electronic ignition work on my 1972 spider convertible?
I found it at a great price, but wanted to make sure it would work.
Jaime
1980 Electronic Ignition with carb does fit 72?
- Your car is a: 1972 Fiat Spider 124
- chrisg
- Your car is a: 1971 FIAT
Re: 1980 Electronic Ignition with carb does fit 72?
yes, fiddle with timing/advance & may need to find a vacuum signal source. if it's used, expect to also replace the vac module if you will be using it.
Chris Granju
Knoxville, TN
Knoxville, TN
- nelsonj
Make sure you have the correct coil - it's likely different from a 72 and won't use an external ballast.
Should be a noticeable improvement in performance and maintenance required.
Simi Valley, California
Spider 1800
Romans 10:9
Thanks for helping out a new guy!
