Clutch replacement: what else while I'm there?
jdeight
Your car is a: 1980 2000
Post by jdeight »
Winter project is going to be replacing the clutch on my '80 Spider. Sounds like I should replace rear main seal and input shaft bearing at the same tome. Anything else I ought to plan tackle while I'm there?
The diagnosis is that my clutch is fried, which I've determined because I can't stay in gear, particularly when accelerating uphill. Engine stays in 3rd, shifting to 4th does nothing.
GeorgeT
Your car is a: 1982 Fiat 124 Spider
Re: Clutch replacement: what else while I'm there?
Post by GeorgeT »
Depending on miles, I would look at the "donut" and the u-joints.
lglade
Post by lglade »
Depending on your budget, I'd give some thought to installing a light-weight flywheel while you're there. The guys who've installed them all swear that they love how much faster that the engine revs.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
klweimer
Post by klweimer »
How's your starter?
nelsonj
Your car is a: 1972 Spider 124
Post by nelsonj »
I second the vote on a starter. Put in one of the small and light weight gear reduction starters - I think Mark has them. I love mine.
A little off target but how are your motor mounts? A new donut is a good move if the old one has any wear. Change the trany oil (with the proper GL5 as I recall) if it needs it.
Simi Valley, California
Spider 1800
Romans 10:9
I'll agree, good time to replace the starter and the flywheel is a great upgrade; it's "free" performance without sacrificing driveability
fiat218
Post by fiat218 »
Over all the engine :D
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
djape1977
Your car is a: 1970 fiat 124bc
Post by djape1977 »
nobody mentions far more important and cheap parts that are otherwise unaccesible...
rear crank oil seal and crank pilot bearing
vandor
Post by vandor »
The original poster did.
jdeight
Post by jdeight »
Just to wrap everything up: I finally finished this job. I ended up replacing the flexible driveshaft joint/guibo, rear main seal (and holder, after I broke the original replacing the first seal), gasket, throw out bearing, clutch plate, disc, pilot bearing, clutch fork boot... Maybe other stuff?
So, why am I taking the time to tell you that I successfully replaced my clutch?
Heck, I'm telling EVERYONE!
klweimer
Post by klweimer »
Sweet! Hard to beat the satisfaction of doing a tough job yourself. So what are you working on next? :)
GeorgeT
Post by GeorgeT »
Replace the Center Driveshaft Support Bearing while you are at it.
