My oil light came on and off as I was driving through some very slow,inclined, twisty roads in the canyons...
How do I get an accurate test of my true oil pressure?
What should it be?
What is it actually showing? Pressure at the crank?
Thanks!
I've heard of the oil light coming on while driving on twisty roads but I'd be wary of it. If it's normal, maybe someone will say. If the connections are good on the oil sender, you can install a mechanical gauge to see what your true readings are. Mine has a mechanical gauge still on it since my oil pressure gauge wasn't reading what it used to. I have it in the engine compartment as a temporary thing since all I wanted to see was whether it was where it should be. The reading should be 62 lbs @ idle and up to 85 lbs while driving. I just removed the sender and screwed the copper line in:
the light should not come on when driving! The most common thing to cause it on winding roads or on hard accel or decel is oil level. If the level is okay, take a close look at the oil pan. If it's dented on the bottom, you may have a broken oil pump pickup. The pump will still work, but it draws oil from higher up rather than at the floor of the pan.
Each time that light flashes, the pump has sucked air and you will destroy the engine in a very short time!
For the spiders that didn't come with a gauge you can replace the clock with
an oil Pressure Gauge , and what mark was talking about the threading
I had some issues in the past with that but found adpaters some place
and made it work .
does anyone know what the thread is on the oil pressure light sensor? I want to put a guage on (which I have) but need to know what you call the metric thread and what size
just for your info Bandit, all spiders came with oil pressure gauges. but not all came with clocks. my 70 didnt come with a clock.
i wouldnt think it would be a big deal to rethread that fitting,
Ok...Now my oil pressure light is going on and off when the needle
is between 10-20. Before, it would only come on when the needle
dropped dead on at zero.
Maybe a bad sending unit?
to get back to the question, it could be a bad sending unit, or the wire to the sender may be grounding somewhere. That would make the light come on even when there is pressure. Having an accurate gauge is important
