Steering wheel
fiat218
Steering wheel
Post by fiat218 »
Take a look at this section of this steering wheel.you see that separate section shaped. That seems to be loose and makes my steering wheel wobbling even if the nut is tight
So does this mean ,get a new one, or try a washer under the nut,I don't think it will work, but what do I know
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
fiat218
Re: Steering wheel
Post by fiat218 »
I notice on the drivers door that where the bolts attach from the hinge to the door, that it cracked
I will assume you can just weld that ?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Steering wheel
it's a little tricky to repair the door cracks, the mounting surface for the hinge has to be flat
vandor
Re: Steering wheel
Post by vandor »
I would replace that steering wheel.
fiat218
Re: Steering wheel
Post by fiat218 »
thanks, good idea to replace
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Re: Steering wheel
Post by fiat218 »
So Cal Mark wrote:it's a little tricky to repair the door cracks, the mounting surface for the hinge has to be flat
it not where the hinge is attached, i will get a photo
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Steering wheel
there shouldn't be any reason for it to crack anywhere else. All of the stress is where the upper hinge attaches
fiat218
Re: Steering wheel
Post by fiat218 »
Yup upper
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
jagonza
Your car is a: 1977 Fiat 124
Re: Steering wheel
Post by jagonza »
if the outside of the door it that ripped up then i can almost guarantee that the inside part of that door - where the hinge actually attaches, is worse off.
not a big deal to fix , open up the door around the hinge and find a good welder.
I have a post on here somewhere about fixing the hinge as do some others.
http://www.fiatspider.com/f15/viewtopic.php?t=33283
hardest part was packing up the door to send to the welders.
1977 Fiat 124 - Frankenstein engine
1999 VW Cabrio - Stock
1988 Fiero GT
And a couple of Daily Drivers
