Hello everyone,
I am doing an engine swap on my 1977 Fiat Spider. The engine I am putting in to replace the 77' engine is a from a 76' Spider. On the 1976 engine, the Alternator is mounted on the passenger side of the engine; versus on the 77' engine the Alternator is mounted on the driver side of the engine. Any suggestions to get around the wiring harness issues? The 77' engine has a stud coming out of the engine block(where the bracket for the Alternator is mounted), looking at the same side on the 1976 engine, there is no hole for a stud. How hard would it be to drill/ tap a hole in the block for the stud? Any other suggestions are greatly appreciated!
Andrew
Engine Swap Wiring Issues
- Your car is a: 1977 Spider
Re: Engine Swap Wiring Issues
I have never performed this engine swap. So others may have another opinion. I would leave the 76 alternator where it is and lengthen the existing alternator wires to reach the passenger side of the car, I would route the wires behind the engine and secure the to the fire wall as tight as possible. for maximum engine clearance.
Thank you! that seems to be the most logical way to get around this. Would anyone happen to have a diagram of the wiring for the starter/ alternator. Last thing I need is a wiring nightmare
- Your car is a: 1985 Spider
Should be able to find it hereSpider1977 wrote:Thank you! that seems to be the most logical way to get around this. Would anyone happen to have a diagram of the wiring for the starter/ alternator. Last thing I need is a wiring nightmare
https://www.mirafiori.com/forum/viewtop ... 49&t=96319
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
I forgot to ask are the alternators on the 76 and the 77 engines the same make and model? If not I would use the one off the 77 so the cars wiring is compatible with the alternator.
I'm not 100% sure if they are the same, but i did plan on keep the same alternator due to the wiring compatibility. Thanks for your input!
