Valve spring compression tool
phaetn
Your car is a: 1974 Fiat Spider 1800
Post by phaetn »
I've got my head off to chase down a coolant leak and want to address a valve seal leak when I'm at it.
I borrowed an OHC valve spring compressor from Parts Source but it won't quite pull the springs enough to loosen the valve from its seat. I wonder if its made for American or Japanese cars with longer springs.
Any suggestions? Was there a specialty tool? Is there a workaround? I'm sooooooo close but can't more forward unless I can loosen the keepers from the valves stem to drop the valves.
phaetn
1974 CS1
32/36 DFEV; CompuTronix ign.
9.8:1 c/r; 40/80 intake cam w/ Isky springs
Vicks' SS header & adj. cam pulleys
A/R's progressive coils, Koni Yellow dampers
205/50-15s on CD-66 style rims
Momo wheel, Corbeau seats w/ 5 pt belt
pics and HD vids
131
Re: Valve spring compression tool
Post by 131 »
I assume the tool you are using is the type similar to a "G clamp". If so, put a washer or other type of spacer between the valve face and the tool, it will give you a bit more spring compression.
Mick.
phaetn
Post by phaetn »
Unfortunately not -- it's not a G clamp. It just fits on the spring side only. Basically it looks like this, though the actuator is different:
http://www.harborfreight.com/universal- ... 60335.html
There are two j "hooks" that fit below the coil of the spring, and then two legs that fit against the spring seat. I guess I need another type...
Thanks and cheers,
phaetn
1974 CS1
pics and HD vids
fiatfactory
Your car is a: 1970 128
Post by fiatfactory »
aj81spider
Post by aj81spider »
I had one like yours and couldn't make it work. Then I bought one like Fiatfactory shows and it was a breeze.
I don't think what you have will work - at least with our engines.
A.J.
2006 Corvette
GTO
Your car is a: 1973 Spyder 1756
Post by GTO »
I have the one in fiatfactory,s picture and have used it for years quite happily on my spider and previous coupes with no problems at all; apart from the small handle,but that's easy to work around.
phaetn
Post by phaetn »
Thanks guys. Turns out I can pick one up for CA$60.
To get the keepers out I just used a socket and a BFhammer, wearing safety glasses, of course. Something soft under the head prevented damage to the valves.
That tool would be required to get the valves and keepers back in. Turns out I bought a new (old) head with back boxes and valves already fitted.
Thanks!
phaetn
1974 CS1
pics and HD vids
Mattiscool
Your car is a: 1978 fiat spinder
Post by Mattiscool »
fiatfactory wrote:.
Could you post a picture of the valve compression tool.
ORFORD2004
Post by ORFORD2004 »
Post by RRoller123 »
Yes that works great, except on Exhaust 4, where some gussets in the cam box (around the disty spot) cause interference. I ground a tiny bit off of a couple of the edges of it and it then it fits perfectly in that troublesome spot. There is a thread somewhere here on the forum about that. Some folks say that you can just put the tool in backwards in that location and use it as is. I haven't tried that. But the tool works and is a good one.
aj81spider
The original post was about a valve spring compression tool. Not sure what the new poster wants, but that's the valve shim removal tool that you guys have posted.
If what Mattiiscool wants is the spring compression tool it was something like this:
https://www.amazon.com/EX-ELECTRONIX-EX ... 142&sr=8-6
A.J.
2006 Corvette
Ah, yes. My mistake.
Mattiscool
Thank you. If I may, if I wanted to check the head for warping, would 0.004 be ok? Thank you!
Shop Manual section 101.01, page 10-47/48
"Using a straight edge, check head for distortion. Lay straight edge across diagonals of gasket surface and lengthwise in the middle. The gap between head and straightedge must not exceed 0.002 inch. If gap exceeds this, reface cylinder head gasket surface"
Mattiscool
Thanks again for your help with my questions. When I removed the heads, I thought maybe I’ll mark the valve caps for indentation (valve cap one, two etc). but they all looked the same, so I thought nay there all the same, so now I’m screwed. LOL
