Clutch
RaneeHobbs
Your car is a: 1976 Fiat 124 Spider
Clutch
Post by RaneeHobbs »
Question: When my Fiat is running, I can not shift. We have adjusted the nut in both directions. Any suggestions?
Ranee
DieselSpider
Re: Clutch
Post by DieselSpider »
RaneeHobbs wrote:Question: When my Fiat is running, I can not shift. We have adjusted the nut in both directions. Any suggestions?
Ranee
Pilot Bearing sticking and needs lubrication or replacement or the clutch arm potentially came off the pivot. Othewise ensure that the clutch cable is still attached to the pedal and not borken.
124JOE
Re: Clutch
Post by 124JOE »
also not pulled thru the fire wall
