Engine Timming
Engine Timming
1981. 2000. Do you disconnect and plug the vacuum line to the distributor when setting the timing? RB
- Patron 2019
Re: Engine Timming
I know that that's common practice. Odd that I don't see it mentioned in the owners manual or the aftermarket Brooklands work manual, which, by the way, has the drain and fill plugs for the manual and automatic transmissions reversed in their photo pg.40. RB
Re: Engine Timming
My vote is noNitrate wrote:I know that that's common practice. Odd that I don't see it mentioned in the owners manual or the aftermarket Brooklands work manual, which, by the way, has the drain and fill plugs for the manual and automatic transmissions reversed in their photo pg.40. RB
Re: Engine Timming
Since it is timed at normal idle speed there is no reason to disconnect the vacuum line. (I am assuming you are talking about ignition timing with a timing light). Put the light on and time it with the line connected.
- Patron 2019
Re: Engine Timming
Hmm.....I'm outvoted, so maybe I am wrong? I thought the advance worked off the manifold, so even at idle, with no load and at lean idle, some vacuum is created.
I guess an easy test is to disconnect the vacuum line at the advance, plug the line and see if the idle changes.
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
Re: Engine Timming
1981.2000. Since I see no mention of disconnecting the vacuum I'm going to time it with the vacuum connected. Vacuum is highest at idle. The mechanical advance weights are not active until higher engine speed. Can someone give me a definitive yes or no on disconnecting the vacuum line? RB
- Your car is a: 1980 spider [carb]
Re: Engine Timming
Funny, I just went through this this morning. I had to replace my vacuum module and when I set the timing I removed and plugged the line because when it was connected it cause the timing to advance a bit.
BTW, just why are there two advance systems, centrifugal and vacuum? Seems kind of redundant, no?
Lately I had been running without the manifold heat shield and now I'm wondering if the heat destroyed the membrane in the capsule, which I assume is rubber. Just in case, I put the heat shield back in place.
1979 Spider
2001Saab SW
2004 Saab Aero
2001Saab SW
2004 Saab Aero
Re: Engine Timming
Two systems because they work differently. Centrifugal works on engine speed alone. Vacuum works via engine load.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
- Patron 2019
Re: Engine Timming
To add a little bit more to Bob's reply.
Vacuum advance works during acceleration or when going up hill at constant speeds.
Previous 76 Spider
Previous 76 Spider
Re: Engine Timming
No vacuum is highest at idle and when cruising at highway speed. When throttle plates open during acceleration going up a hill the vacuum decreases, that's when the centrifical weights take over. That's why there are two systems. RB
Re: Engine Timming
It would be, if vacuum for the distributor is taken from the manifold. It isn't. It's taken from the place in the carb that operates vacuum secondaries. It's higher vacuum when more air is flowing.
Re: Engine Timming
Your confusing the fuel system with the ignition/ advance /retard system that is regulated by engine vacuum and the mechanical advance weight in the distributor. You are correct in saying that a ported vacuum take off point results in no timing advance at idle. But once the throttle plates are cracked just a hair it's just like manifold vacuum. It decreases when you open the throttle going up hill and increases when you are in cruise mode. RB
- Your car is a: 1981 2000
Re: Engine Timming
Brads books says to take off the vac line.
Re: Engine Timming
Gandyrail, Thanks very much for letting me know that. I have Brads book but missed that refrence. RB
