I have read archived post on the heat issue, and was hoping to open the discussion again. I have the carpet and old pad out. I was out on a drive on a cool evening and noticed a lot of heat radiating from the transmission area, including the floor near the transmission. I did not remove the original padding around the tranny. Does this work well for heat containment, or should I remove and replace with different material. I plan to put down dynamat type material on the floors.
I was also wondering if it is feasible to put some kind of heat blanket around the top of the tranny itself to keep heat from entering the cockpit?
