Just a couple of quick questions:
Should some kind of sealant be used on my new head to cam box gaskets? How about on the cylinder head gasket?
sealants
- bradartigue
Re: sealants
No and hell no. If you need a sealant then a surface is not prepared correctly. You can get a head-to-cambox gasket with a silicone bead in the center, which seals up minor imperfections if necessary. On the head gasket, absolutely not.
1970 124 Spider
http://www.artigue.com/fiat
