Thank you! I think it is cracked, how do you fix it or is it easier to put a replacement door in its place? Any suggestions on the best places to find used doors in Texas. Also, I was told that sometimes they act like they don't want to start and you have to give them a little push and they will start. I had this happen to me and wondered if there was a way to keep this from happining or do I just need to park where I can always push!
Thanks for the info
Thank you!
No way!! That's not true. If you're having starting problems, then there's a problem with your car, and you need to fix it. Post a detailed report in the proper area here, and everyone can help.
That's not something you have to live with, as you should have no problems as long as it's looked after!
Chris
Chris
