noise from rear end
- red107
- Contact:
noise from rear end
Pulled the ole girl out of storage today. Weather here in East Carolina is very nice. As I drove off I heard a clunking noise coming from the rear end/driveshaft. Like something was loose. I got underneath and couldn't find anything loose. I live less than a mile from our storage unit so I drove her to the house. As I shifted to 2nd on up the noise is not there. Its only in 1st gear. After another inspection back at the house I couldn't find anything loose. I went on another drive and again no clunking noise only when starting out in 1st gear. Any Ideas?
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
Re: noise from rear end
Driveshaft center support bearing
U-joint?
Any noise/clunk when you go from decell to accel in other gears. Ujoint end moving in its cap.
- red107
- Contact:
Thanks guys, The drive shaft center bearing was replaced recently. I was leaning towards bushing in the trailing arms and pan hard bar. But the U-joint could be the culprit. I will look at all of those. Thanks again.
