Brake Light Ground
Ragno
Brake Light Ground
Post by Ragno »
Hi All,
I'm having an issue with my brake lights not working. I have tested the switch and it seem to be ok. I believe it is probalby an issue with the ground. I can't seem to locate a seperate ground for the brake lights. Does anyone know where it is? I'm guessing on the left side of the trunk below the antenne? Thanks. :?:
Re: Brake Light Ground
you have the circuit boards on your lights, and the connections can be troublesome once they become corroded
rlux4
Patron 2022
Patron 2022
Post by rlux4 »
The driver side circiut board has the shared ground connection. I think the ground plate your talking about is for the trunk light, if it's the one screwed onto the wall at the back seat.
Ron Luxmore
rlux2n2@gmail.com
Ragno
Post by Ragno »
Thanks that took care of it. :P
