Passenger side:
Drivers side:
The previous owner doesn't remember where he got it except to say it was either IAP or Ricambi but is not sure which.
Did this fail because it needed to be shimmed or just due to thin metal and not deep enough welds holding the wrapped ends together?
Sunday I picked up a spare that Vampyrepro had in his barn and will be cleaning it up with a cup brush for a more thorough inspection before refinishing and installing it. The spare which is believed to be OEM appears a bit beefier than whats on there.
Any words of wisdom on other things to check while pursuing this? All the bushings, ball joints, tie rod ends, etc were replaced within the past 8,000 miles however the tie rod ends while appearing new/tight do creak and are the sealed variety so they can't be greased aside from removing the boots and repacking them from there. Physical inspection shows all other components to be good too. I did on principle clean and repack the front wheel bearings which were in good condition replacing the seals. Front calipers have about 8,000 miles on them, flex lines, pads and rotors are new and have only around 1,000 miles on them.
