1981 timing
Schaubb
Your car is a: 1981 fiat spider
1981 timing
Post by Schaubb »
I recently performed a top end service to a spider I bought a few years ago. It was last inspected in 2002 so I'm guessing that was the last time it ran. I removed the head, completely disassembled it and thoroughly cleaned it. The cylinders looked great. I installed new valve seals, lapped the valves, and reassembled the head/ cam boxes. I changed the water pump and idler pulley while I had it all apart. My question involves proper timing. When I look online it seems to show the timing mark on the crank at the 1 o'clock position. However when #4 cyl is at TDC mine is approx at 11 o'clock. There is also a metal timing tab similar to what I've seen on a small block Chevy that lines up perfectly is this correct? I have some more things to complete before I try to start it and would like to make sure this is correct before I do. My past experience had been x/19's and MG's so this is new territory for me. Any help is appreciated!
