Rear Sway Bar & Lowering Springs - Installation Sequence?
SunnySideUp
Your car is a: SOLD
Post by SunnySideUp »
I'm doing some work under my Spider and have a rear sway bar to install "while I'm there." I have been considering the installation of lowering springs in the future. Should I hold off and wait to install the sway bar until after the lowering springs are installed?
Thanks!
SunnySideUp
124JOE
Re: Rear Sway Bar & Lowering Springs - Installation Sequence?
Post by 124JOE »
yes wait
or remove to lower you car and install again
SunnySideUp
Your car is a: SOLD
My main concern is whether or not the geometry will be significantly thrown off causing me to re-drill holes in the subframe if I were to install the sway bar now and then lower it a few months later or next year.
SunnySideUp
124JOE
Post by 124JOE »
ya that sounds right
I would wait
