My car has the two little bottles style reservoir with a cap that looks like this;
While cleaning them out one day I noticed that the cap is vented through the center. Is this intentional or has that rubber/plastic seal in the center of the cap just worn out?
I thought brake fluid was hydrophilic as in it likes to absorb moisture from the atmosphere. Or was this not an issue with brake fluid in the 70s?
Vented brake fluid reservoir?
- V12StealthHunter
- Your car is a: 1971 Fiat 124 Spider
1971 Fiat 124 Sport Spider
- azruss
Re: Vented brake fluid reservoir?
That's how they are built. That button it pretty tight so it may be just a plug for a cap without a low fluid sender.
Hygroscopic, so in theory should be replaced annually. The reservoir has to be vented or the fluid level can't fall as the pads wear. Modern vehicles use a flexible seal that can expand into the reservoir as the level falls, but still excludes the outside air.V12StealthHunter wrote:I thought brake fluid was hydrophilic as in it likes to absorb moisture from the atmosphere.
Mick.
- V12StealthHunter
Ah good to know. Had no idea thats how it is on all cars.131 wrote: Hygroscopic, so in theory should be replaced annually. The reservoir has to be vented or the fluid level can't fall as the pads wear. Modern vehicles use a flexible seal that can expand into the reservoir as the level falls, but still excludes the outside air.
> I think your cap is missing the membrane button and contacts for low-level warning
His Spider never had that, Fiat started that in mid-77.
You can have that for your Fiat too with these two parts:
http://www.autoricambi.us/product/BR9-0 ... er-Insert/
http://www.autoricambi.us/product/BR9-0 ... rvoir-Cap/
What a top idea, never seen one of those for an early Fiat.
Mick.
