Heat settings: Hot and Less Hot
burlybryan
Post by burlybryan »
This past winter I put a new heater core and valve in the car ('82 FI 2000). It had been bypassed for ages (by the PO) due to a leaking valve.
The console lever smoothly turns the valve fully off and fully on, but when off, there is still quite a bit of residual heat (when "on" it's cooking). It's been a nice side effect in the cooler mornings, but now that summer is fully on it's kinda uncomfortable...
Is this "normal" Fiat heater operation or did I reverse something? It seems like the core is getting circulation or at least warmed like a heat sink.
Thanks.
Bryan
burlybryan
'82 Spider 2000 FI
'12 500 Sport (Verde Oliva) - wife's daily driver - when it's not being fixed at the dealer...
btoran
Your car is a: 1975 Fiat 124 Sport Spider
Re: Heat settings: Hot and Less Hot
Post by btoran »
when turned "off", where is the residual heat coming from? is it thru the vents or elsewhere? there is a foam/rubber inner boot that goes under the shifter console. over time, they wear out and let heat in through the shift area. i swapped my original/falling apart one for a new one and it made a world of difference.
1975 Fiat 124 Spider
4uall
Post by 4uall »
burlyb
Your car is a: 1982 Fiat Spider 124 2000 FI
Post by burlyb »
Thanks 4uall - did all that with the console removal. New boot, foam, insulated everything. The residual heat is def most apparent in the passenger side - the pipes and heater valve are super hot. It's HVAC heat, not from the trans tunnel. The heater core is warming up as well because it will come out the vents if I select defrost. The (aftermarket Pioneer) radio will occasionally kill due to the heat in the dash/console. It's weird - or maybe normal...I have no baseline.
Maybe I should just focus on all the fluid leaks and leave this alone :lol:
Post by RRoller123 »
The valve cable loose/broken and not closing the valve? So hot coolant constantly flowing through heater?
burlybryan
Watching the cable actuate the valve under the dash, it goes to full stop at open and closed. I'll have to check if the other pipe is cooler or as hot next time I'm out. I suppose it could just be the valve and pipes warming up from the thermal transfer of engine coolant and convecting up into the dash.
burlybryan
'82 Spider 2000 FI
Ragno124
Your car is a: 1981 124 Spider
Post by Ragno124 »
It's possible that you need to find the "sweet spot" on the valve as I have found on my '81 Spider that if I slide my lever to full closed that it acutely goes too far and opens up the valve again and it gets hot. So I have to go to fully closed then go back about a 1/4 inch to get it to stay fully closed and then it's just cool air from the vents.
Steve Muzzillo
1981 124 Spider 2000 (ex-turbo)
2006 Acura MDX
2008 Honda CRV
2014 GMC Acadia
2017 Acura RDX
81SPIDERMATT
Post by 81SPIDERMATT »
Ragno124 wrote:It's possible that you need to find the "sweet spot" on the valve as I have found on my '81 Spider that if I slide my lever to full closed that it acutely goes too far and opens up the valve again and it gets hot. So I have to go to fully closed then go back about a 1/4 inch to get it to stay fully closed and then it's just cool air from the vents.
I hesitated to say the same thing thinking that my valve is just getting old.... but I also have a sweet spot
majicwrench
Post by majicwrench »
Are you shuting off the air flow as well?? Gotta shut that big flap under cowl or air will keep flowing thru, and yes, core will stay hot even wo water flowing thru it.
4uall
Post by 4uall »
burlybryan
majicwrench wrote:Are you shuting off the air flow as well?? Gotta shut that big flap under cowl or air will keep flowing thru, and yes, core will stay hot even wo water flowing thru it.
This is definitely part of it. The cable or flap is hanging up and doesn't allow the lever to move all of the way. Gonna suck to trace that. I feel like all the dash bits are held together by a delicate balance of friction.
Will look for the "sweet spot" as well. :wink:
Thanks guys.
burlybryan
'82 Spider 2000 FI
